Hello. I'm working on a Machine Learning problem where I need to train the model to calculate the energy consumption of an HVAC system under specific conditions (both controllable parameters such as the flow rate of the coolant and uncontrollable parameters like temperature and humidity outside and the setpoint temperature). I found the following dataset that is close to what I'm looking for which was simulated using OpenStudio, but I couldn't replicate this for Indian conditions and I ran into some version dependencies. I don't have a background in HVAC modelling and I come from a CS background. So forgive me for any mistakes in the terminology. I would greatly appreciate it, if you could point me to some software or an existing dataset that helps me to achieve this.
