I'm learning using the book 'Building Energy Modeling with OpenStudio' and in the first simulation, when I went to run the simulation, a fatal error happened.
Initializing workflow. Processing OpenStudio Measures. Translating the OpenStudio Model to EnergyPlus. Processing EnergyPlus Measures. Starting Simulation. EnergyPlus Starting EnergyPlus, Version 9.3.0-baff08990c, YMD=2022.03.06 12:20 **FATAL:Errors occurred on processing input file. Preceding condition(s) cause termination. EnergyPlus Run Time=00hr 00min 0.39sec Program terminated: EnergyPlus Terminated--Error(s) Detected. Failed.
[12:20:53.264533 WARN] Reporting Measure at C:/Users/BARRET~1/AppData/Local/Temp/osmodel-1646574899-0/resources/measures/OpenStudioResults/measure.rb is using the old format where the 'arguments' method does not take model. Please consider updating this to def arguments(model).
[12:20:57.353245 WARN] EnergyPlus returned a non-zero exit code. Check the stdout-energyplus log.
[12:20:57.411409 ERROR] :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/energyplus.rb:187:in call_energyplus'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:in step'
:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:inrun'
:/openstudio_cli.rb:973:in execute'
:/openstudio_cli.rb:763:inexecute'
:/openstudio_cli.rb:1757:in <main>'
eval:149:ineval'
eval:149:in require_embedded_absolute'
eval:123:inblock in require'
eval:117:in each'
eval:117:inrequire'
eval:3:in <main>'
[12:20:57.416453 ERROR] Found error in state 'simulation' with message [":/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/energyplus.rb:187:incall_energyplus'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:973:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1757:in<main>'\neval:149:in eval'\neval:149:inrequire_embedded_absolute'\neval:123:in block in require'\neval:117:ineach'\neval:117:in require'\neval:3:in<main>'::/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/energyplus.rb:205:in rescue in call_energyplus'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/util/energyplus.rb:128:incall_energyplus'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in perform'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:292:instep'\n:/ruby/2.5.0/gems/openstudio-workflow-2.0.0/lib/openstudio/workflow/run.rb:234:in run'\n:/openstudio_cli.rb:973:inexecute'\n:/openstudio_cli.rb:763:in execute'\n:/openstudio_cli.rb:1757:in<main>'\neval:149:in eval'\neval:149:inrequire_embedded_absolute'\neval:123:in block in require'\neval:117:ineach'\neval:117:in require'\neval:3:in<main>'"]}
How can I resolve this?
