E+ does not allows non-positive peak_freezing_temperature
Hello, I am trying to model a PCM layer in a wall. This PCM has phase-change hysteresis, with a peak freezing temperature below 0°C. This 0°C, which is not unusual. Running EnergyPlus versions 9.5 or 9.6 (the latest ones)This causes a the following severe error error:
Program Version,EnergyPlus, Version 9.6.0-f420c06a69, YMD=2022.03.07 16:28,
* Severe * <root>[MaterialProperty:PhaseChangeHysteresis][C5 - 4 IN HW CONCRETE][peak_freezing_temperature] - "-2" - Expected number greater than 0.000000
* Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination.
To get an error like this, just take the input file, causing termination. file 1ZoneUncontrolledWithHysteresisPCM.idf from the folder "ExampleFiles" within the EnergyPlus installation folder, and change either the peak_freezing_temperature or the peak_melting_temperature by a negative number. For isntance, I would appreciate your help set peak_freezing_temperature to circunvent this issue. -2.
