Dear,
I'm developing new Reinforcement Learning Control Strategies and I'm using E+ as a test bed for the algorithms. I managed to use only
t_in_air, !- Name
VAV SYS 1 OUTLET NODE, !- Actuated Component Unique Name
System Node Setpoint, !- Actuated Component Type
Temperature Setpoint; !- Actuated Component Control Type
as an actuator to optimize the Energy Consumption in the building by varying the temperature. Since I will like to give more control actions I have started to use the mass flow rate and I have created the following actuator:
mdot_fan, !- Name
SUPPLY FAN 1, !- Actuated Component Unique Name
Fan, !- Actuated Component Type
Fan Air mass Flow Rate; !- Actuated Component Control Type
Using the ExternalInterface:Variable, EnergyManagementSystem:ProgramCallingManager and EnergyManagementSystem:ProgramI pass and set my control actions:
act_calls1, !- Name
InsideHVACSystemIterationLoop, !- EnergyPlus Model Calling Point
Act; !- Program Name 1
Act, !- Name
SET t_in_air = tair, !- Program Line 1
SET mdot_fan = mdot; !- Program Line 2
mdot, !- Name
1; !- Initial Value
tair, !- Name
1; !- Initial Value
I have tried with both AirTerminal:SingleDuct:ConstantVolume:NoReheat and AirTerminal:SingleDuct:VAV:Reheat.
With AirTerminal:SingleDuct:ConstantVolume:NoReheat the RL algorithm discovers a strange behaviour of E+ that makes the temperature to follow the E+ base line in blue but the HVAC consumption is almost 0
With AirTerminal:SingleDuct:VAV:Reheat the VAV SYS 1 OUTLET NODE it does not flow the controls that I pass to E+ (in green what E+ does in red what I wanted to do).
At the links you find the zips with the IDF, the control_actions and the E+ output for both cases.
https://www.dropbox.com/s/ektupyzrxaqbue7/VAV_costantVolume.zip?dl=0
https://www.dropbox.com/s/ev9ofl1wptpx0i5/VAV_reheat.zip?dl=0
