Need help with the err. document
Hi thanks in advance for any advise.
I have run a simple model with geomotry created by sketchup, and I add some simple properties to it,such as weather conditiong, construction set.
and then I ran this model, it seems to be succeed, but failed in the last step. Like the following picture. image description
Here is part of the err. document. * Warning * CheckEnvironmentSpecifications: SimulationControl specified doing design day simulations, but no design environments specified. * ~~~ * ...No design environment results produced. For these results, add appropriate SizingPeriod:* objects for your simulation. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS ON CONTINUOUS", Blank Schedule Type Limits Name input -- will not be validated. * Warning * CheckUsedConstructions: There are 32 nominally unused constructions in input. * ~~~ * For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings; * Warning * Output:Meter: invalid Key Name="ELECTRICITY:FACILITY" - not found. * Warning * Output:Meter: invalid Key Name="NATURALGAS:FACILITY" - not found. * Warning * Output:Meter: invalid Key Name="DISTRICTCOOLING:FACILITY" - not found. * Warning * Output:Meter: invalid Key Name="DISTRICTHEATING:FACILITY" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="NATURALGAS:FACILITY" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="ELECTRICITY:FACILITY" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="ELECTRICITY:FACILITY" - not found.
** Warning ** CheckEnvironmentSpecifications: SimulationControl specified doing design day simulations, but no design environments specified.
 * **   ~~~   * ** ...No design environment results produced. For these results, add appropriate SizingPeriod:* objects for your simulation.
 * Warning * ** Warning ** ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated.
 * Warning * ** Warning ** ProcessScheduleInput: Schedule:Constant="ALWAYS ON CONTINUOUS", Blank Schedule Type Limits Name input -- will not be validated.
 * Warning * ** Warning ** CheckUsedConstructions: There are 32 nominally unused constructions in input.
 * **   ~~~   * ** For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings;
 * Warning * ** Warning ** Output:Meter: invalid Key Name="ELECTRICITY:FACILITY" - not found.
 * Warning * ** Warning ** Output:Meter: invalid Key Name="NATURALGAS:FACILITY" - not found.
 * Warning * ** Warning ** Output:Meter: invalid Key Name="DISTRICTCOOLING:FACILITY" - not found.
 * Warning * ** Warning ** Output:Meter: invalid Key Name="DISTRICTHEATING:FACILITY" - not found.
 * Warning * ** Warning ** Output:Meter:MeterFileOnly: invalid Key Name="NATURALGAS:FACILITY" - not found.
 * Warning * ** Warning ** Output:Meter:MeterFileOnly: invalid Key Name="ELECTRICITY:FACILITY" - not found.
 * Warning * ** Warning ** Output:Meter:MeterFileOnly: invalid Key Name="ELECTRICITY:FACILITY" - not found.found.
Thanks
**   ~~~   ** ...No design environment results produced. For these results, add appropriate SizingPeriod:* objects for your simulation.
**   ~~~   ** For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings;
Thanks
Thanks
Thanks
Need help with the err. documentdocument of OSM model creat in SketchUp plugin
Hi thanks Hi, Thanks in advance for any advise.
and And then I ran this model, it seems to be succeed, but failed in the last step. Like the following picture. image description
Here is part of Like the err. document.following picture. https://drive.google.com/file/d/1fSGWLnxloA18zOO0NAb5QolVCaluDVvm/view?usp=sharing
You can check all my documents here.
https://drive.google.com/drive/folders/1WhoFT6pSX0bVFDxu-orOtsSav04ztN9q?usp=sharing, https://drive.google.com/file/d/1Wqgsqdal78XMrPyir8PbLHjBEqAXz_jd/view?usp=sharing
Thanks
Need help with the err. document of OSM model creat in SketchUp plugin
Like the following picture. https://drive.google.com/file/d/1fSGWLnxloA18zOO0NAb5QolVCaluDVvm/view?usp=sharing
Thanks
Some of you guys have ran my IDF file, and found no severe errors.@Jim Dirkes
First, I'd like to say it's so kind of you to try your best to help me solve the problem.
But if you guys look into the results of Energyplus carefully, you can find it really wierd.
First, there isn't any ''Building Area'' ! image description](/upfiles/16461112497675422.jpg)
Second, the Envolope part isn't identified by openstutio(or energyplus) too. image description
As a matter of fact, also no ''Site and Source Energy'' in the model too. image description
Also, if you ran the osm file which is equal to the IDF file(osm file is converted into IDF file to achieve the goal of building energy simulation).
you may find the reports of Energyplus and Openstutio conflicts. (Don't forget to drag the ''OpenStutio Results'' from the library) image description
Run the osm file after add the ''OpenStutio Results''. image description
And it shows that ''Envolope Summary'' fails too(just like what the Energyplus Report said) image description
Here is the results.
Energyplus Results: https://drive.google.com/file/d/1rRYmQ0fQQsKLYp_58NqJ_9AryQJONdQ4/view?usp=sharing
OpenStutio Results: https://drive.google.com/file/d/1XaXe2R26zT7omXebh7eB1AEJMSToExVO/view?usp=sharing
Thanks.
First, there isn't any ''Building Area'' ! image description](/upfiles/16461112497675422.jpg). https://drive.google.com/file/d/10XxAVkn3TBG8VKK5nnCz_u4jxM9o229u/view?usp=sharing
Thanks.
