I'm trying to create a DOE prototype building from the measure "Create DOE Prototype Building" for NECB 2011 (Canada).
I have a local instance of the measure because I had to correct the code, I had the following error: "wrong number of arguments (given 5, expected 0; required keywords: template, building_type, epw_file)". So I passed these 3 arguments in the function prototype_creator.model_create_prototype_model(). The error disappeared after this modification.
But now, I have the following error: "File does not exist: :/ruby/2.7.0/gems/openstudio-standards-0.2.14/lib/openstudio-standards/standards/necb/NECB2011/data/geometry/SmallOffice.osm". I suppose that this file does not exist in the embedded openstudio-standards gem.
I've already tried the steps recommended in the link: CLI reference in order to install a local gem, but still no success.
Thank you for your help!
