In EnergyPlus,
①How to use the heat generated by a data center (one room) to heat the office (another room in the same building)?
②How to use the heat generated by a data center to produce domestic hot water?
Any suggestions will be appreciated.
The SVG and IDF file was there. Origin file based on PNNL Large Office building. https://drive.google.com/drive/folders/1dfzVvScnO67x5UY7OjiMwX8Yoe16AWXK?usp=sharing
