Hello I am currently using the Energyplus program to build an Ideal HVAC load system consisting of ducts, blowers, and zones. In this regard, I would like to inquire about the questions below.
I want to know if I can implement a fan system in the middle of the duct. If it is possible to implement the blower system, please tell me the class required for implementation or how to implement it. (For example, connect the duct1 input node in the Ideal HVAC output node, and then connect the duct1 output node and the blower input node. After connect the blower output node and duct 2 input node, connect the duct 2 output node and the zone inlet node. If implementation is possible, please explain in detail using class.)
In the Ideal HVAC system, we would like to build a system that passes through the duct and enters the zone. I'd like to know if I can connect with the duct node in the Ideal system here. For example, I would like to know if I can connect to the duct input node to Ideal HVAC output node and connect the duct output node to the zone input node. Please explain this in detail if possible.
Finally, if we can build a blower system in the duct, we would like to increase the number of blowers or change the position of the blower in the duct. I'd like to know if this is also possible.
Thank you for reading my long question.
