Hi,
I was wondering if anyone could assist me with the following question in EnergyPlus. In particular, I modeled a single office room (by modifying IECC_OfficeSmall_STD2018_Denver prototype). Dimensions are 201510 (ft). As far as the HVAC system, a Heat Pump is modled to provide cooling and heating. The IDF file could be found [here]:(https://drive.google.com/file/d/1tRvxDVF9_Fc1Zsjjjtyns539qujBt-Ts/view?usp=sharing)
However, the issue is that the model cooling loads for early hours of the day (in summer season) is ossilating. In specific, and for instance for June 27, cooling loads falctuates betwwn midnight and 7 am between zero and 1952 W, as showed below:
Any help would be greatly appreciated.
Thanks, Mohammad
