Hello, I am new to using OpenStudio and have been trying to run a DOE prototype model with an HVAC system I added. I have not been able to have a successful run and would appreciate any tips.
Here is a copy of the run.log I receive:
[10:36:52.173185 WARN] EnergyPlus returned a non-zero exit code. Check the stdout-energyplus log.
[10:36:52.173570 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus failed and did not create an eplusout.end file. Check the stdout-energyplus log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:236:in call_energyplus'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'
:/openstudio_cli.rb:1067:in execute'
:/openstudio_cli.rb:803:inexecute'
:/openstudio_cli.rb:1855:in <main>'
eval:186:ineval'
eval:186:in require_embedded_absolute'
eval:171:inblock in require_embedded'
eval:165:in each'
eval:165:inrequire_embedded'
eval:124:in require'
eval:3:in<main>'
[10:36:52.175831 ERROR] Found error in state 'simulation' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus failed and did not create an eplusout.end file. Check the stdout-energyplus log., :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:236:in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:inperform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:inrun'\n:/openstudio_cli.rb:1067:in execute'\n:/openstudio_cli.rb:803:inexecute'\n:/openstudio_cli.rb:1855:in <main>'\neval:186:ineval'\neval:186:in require_embedded_absolute'\neval:171:inblock in require_embedded'\neval:165:in each'\neval:165:inrequire_embedded'\neval:124:in require'\neval:3:in<main>'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:241:in rescue in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/energyplus.rb:238:incall_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run'\n:/openstudio_cli.rb:1067:inexecute'\n:/openstudio_cli.rb:803:in execute'\n:/openstudio_cli.rb:1855:in<main>'\neval:186:in eval'\neval:186:inrequire_embedded_absolute'\neval:171:in block in require_embedded'\neval:165:ineach'\neval:165:in require_embedded'\neval:124:inrequire'\neval:3:in `<main>'"]}
Thanks
