I have recently updated from OpenStudio 3.2.1 to 3.3.0 and models that ran okay previously now fail and give the following message when using this EnergyPlus measure. They run properly without the measure.
"No windows found in selection matching given construction. This means your model lacks windows or lacks windows with the specified construction."
Has anyone else run into the problem and what is the likely cause?
