The "Material:RoofVegetation" has internal parameters such as Height, LAI (Leaf Area Index), RStomata, etc. Some of these parameters will change in a multi-week simulation. For example, the plants will grow in height and the leaf area will increase (or decrease by if leaves are shed). There are good relations to predict trajectories of these parameters using the solar radiance, zone temperature and humidity history.
I would like to write a plugin where I monitor and possibly change the RoofVegetation parameters at every simulation step. There are plugin examples (e.g. PythonPlugin1ZoneUncontrolledCondFD.idf) where material properties such as thermal conductivity are changed using the api.exchange.set_actuator_value method.
Can I do similar with RoofVegetation parameters Height and LAI?
