Hi...
I am trying to use ANN model to predict the window opening and closing. For this I have used sensor data to get indoor and outdoor temperature. I have also trained and imported by ANN model using pickle library. The ANN model is named as 'ANNclassify'. The value from the ANNclassify will be given to actuator, which will change my schedule.
For some reason, the code is giving me the following error.
Traceback (most recent call last): File "<ipython-input-73-8928f248afed>", line 23, in my_function AttributeError: 'float' object has no attribute 'apply' Exception ignored on calling ctypes callback function: <function my_function="" at="" 0x000001dc00155d30="">
My code is as follows: api = EnergyPlusAPI()
Loading the ANN model using pickle function. pick
with open('ANNClassify.pickle', 'rb') as f: ANNclassify = pickle.load(f)
def my_function(state):
if api.exchange.api_data_fully_ready(state): #Necessary condition
if api.exchange.warmup_flag(state) == 0:
To_handle = api.exchange.get_variable_handle(state, "Site Outdoor Air Drybulb Temperature", "Environment")
Ti_handle = api.exchange.get_variable_handle(state, "Zone Mean Air Temperature", "SecondFloor:Unit1XBR")
# "Zone Thermostat Cooling Setpoint Temperature", zone_name)
To = api.exchange.get_variable_value(state, To_handle)
Ti = api.exchange.get_variable_value(state, Ti_handle)
To = To.apply(stats.zscore)
Ti = Ti.apply(stats.zscore)
var_list = [Ti, To]
var_list = torch.FloatTensor(var_list)
var_list = var_list.reshape(1,2)
Modified_Sch = ANNclassify(var_list)
Modified_Sch_1 = Modified_Sch.item()
if Modified_Sch_1 <= 0:
Modified_Sch_1 = 0
else:
Modified_Sch_1 = 1
sch_handle = self.api.exchange.get_actuator_handle(state,
"SCHEDULE:COMPACT",
"SCHEDULE VALUE",
"LIV1XWIN_SCH")
self.api.exchange.set_actuator_value(state, sch_handle, Modified_Sch_1)
state = api.state_manager.new_state() #Necessary condition api.state_manager.reset_state(state) api.runtime.callback_begin_zone_timestep_after_init_heat_balance(state, my_function) api.runtime.run_energyplus(state, [ '-d', '/Users/.../Desktop/ReOrg/EPlus_Files', '-w', '/Users/.../Desktop/ReOrg/EPlus_Files/Weather_File_SYR.epw', 'C:/Users/.../Desktop/ReOrg/EPlus_Files/Heating_design_new.idf' ] )
Is there any way I can solve this issue? Thanks..
