Hi all,
As the title says I am trying to generate parametric analysis however, when I pass the function my argument for "parameter" I am unable to assign it as an EPPY attribute and get this error:
"eppy.bunch_subclass.BadEPFieldError: unable to find field parameter"
In this case I am trying to tell it to select the "Tilt_Angle_from_WindowDoor" field in the "Shading:Overhang" Object but it doesn't seem to take. I know the field name is correct as it works outside of the function.
def single_valStudy(value_range,IDF,IDF_obj,obj_range,parameter,FileName,folder_path):
study=[]
for i in range(0,(len(value_range)),1):
for b in range(0,obj_range,1):
idf_l=IDF
a=idf_l.idfobjects[IDF_obj][b]
c=parameter
d=a.c=value_range[i]
study.append(idf_l)
os.chdir(folder_path)
idf_l.saveas(FileName.format(d))
return study
