Is there a documented workflow or example to run several existing OpenStudio measures from the BCL (i.e., "ZEDG VRF with DOAS" followed by "SetSpaceInfiltrationPerExteriorArea") within an OpenStudio SDK scripting environment? I'm trying to programmatically look-up / apply several measures within a single script, and hopefully without reverse engineering the measures in their entirety.
