for the first time I'm trying to set up a model with passive cooling ceiling, using ground heat exchanger. I get some errors, but I see the settings in UI, I'm not sure what is missing. Could somebody help me with this? 1 2 3
Program Version,EnergyPlus, Version 9.5.0-de239b2e5f, YMD=2022.01.11 19:09, * Severe * <root>[GroundHeatExchanger:HorizontalTrench][Horizontal Ground HX] - Missing required property 'undisturbed_ground_temperature_model_type'. * Severe * <root>[Pipe:Indoor][Indoor Pipe] - Missing required property 'construction_name'. * Severe * <root>[Site:GroundTemperature:Undisturbed:KusudaAchenbach][Horizontal Ground HX Ground Model] - Missing required property 'soil_density'.
* Severe * <root>[Site:GroundTemperature:Undisturbed:KusudaAchenbach][Horizontal Ground HX Ground Model] - Missing required property 'soil_specific_heat'. * Severe * <root>[Site:GroundTemperature:Undisturbed:KusudaAchenbach][Horizontal Ground HX Ground Model] - Missing required property 'soil_thermal_conductivity'. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination.
