https://bigladdersoftware.com/epx/docs/9-5/input-output-reference/group-radiative-convective-units.html#zonehvaccoolingpanelradiantconvectivewater
I want to do a passive cooling system in slab using underground water, in the E+ ZoneHVAC:CoolingPanel:RadiantConvective:Water, it seems a fixed water temperature should be given. Is there any method to coupling this field to the underground water temperature profile?
