I am writing a measure to mass-assign materials to constructions and constructions to default construction sets. The following bit of code produces a new DefaultSurfaceConstructions with option = true, but not with option = false.
if option then
exterior_surface_constructions = OpenStudio::Model::DefaultSurfaceConstructions.new(model)
exterior_surface_constructions = exterior_surface_constructions.setName(exterior_surface_constructions_name)
surface_constructions = model.getDefaultSurfaceConstructionss()
surface_constructions.each do |surface_construction|
runner.registerInfo("Default Surface Construction = #{surface_construction.name()}")
end
exterior_surface_constructions = surface_constructions[-1]
end
if not option then
exterior_surface_constructions = model.getDefaultSurfaceConstructionsByName(exterior_surface_constructions_name)
runner.registerInfo("ESC after ByName: #{exterior_surface_constructions}")
if exterior_surface_constructions.is_initialized then
exterior_surface_constructions = exterior_surface_constructions.get
runner.registerInfo("ESC after Get: #{exterior_surface_constructions}")
else
runner.registerInfo("ESC after new and name: #{exterior_surface_constructions}")
end
end
I find that I am having to take a similar detour to generate a new DefaultConstructionSet, also. It seems that the option = false approach would be the more correct one as it first checks if the object already exists, and it works with other objects in OpenStudio 3.2.1, but not with these two?
