Hello, I want to simulate a green roof using DesignBuilder/EnergyPlus. As far as I understood there are several layers required for green roof such as drainage layer, protection layer, root barrier membrane and filtering membrane. I wanted to ask how I can find the properties of these materials (conductivity, density, thickness and specific heat). Thank you in advance for any help that you can provide.
