Hello, I simulated a multifamily building with characteristics for Buffalo, NY location through resstock 2.2.5 version. I added an openstudio results measure at the end to view the results and retained the timeseries CSV export measure present by default. I simulated multiple buildings but using the one above as example. The usage values for total electricity and end uses from timeseries csv export and openstudio results html file do not agree surprisingly. The enduse timeseries has vastly different values. Has anyone encountered a similar issue? I am not aware of the process to upload files here and can upload the result file is it helps in the resolution. Looking for a solution/explanation for this weird behavior
