Hello. I am using openstudio applicaton 1.2.1. When I try to add a measure to read results, I only get Openstudio Results, which generates results in IP units. I wasn't able to find the reporting measure called OpenStudio Results (PH units) that I have used with preview versions of OpenStudio. I have looked for this measure in BCL but it only appears the IP version. Please, if someone knows where I can find this measure, I would appreciate much. Thank you.
