I am running energyplus on macOS and usually this works fine (enough). My typical workflow is that I copy the required binaries into a temporary folder along with a in.idf
file. In the past I had issues when I forgot to copy one of the library files along, such as libgcc_s.1.dylib
. Now I wanted update from energyplus 9.2.0 to 9.6.0 and I am not able to resolve this issue. When I try to run the Slab pre-processor as a dry-run, even from within the installation path, I get this issue:
/Applications/EnergyPlus-9-6-0/PreProcess/GrndTempCalc/Slab
dyld: Library not loaded: /usr/local/opt/gcc@9/lib/gcc/9/libgfortran.5.dylib
Referenced from: /Applications/EnergyPlus-9-6-0/PreProcess/GrndTempCalc/Slab
Reason: image not found
[1] 53934 abort /Applications/EnergyPlus-9-6-0/PreProcess/GrndTempCalc/Slab
All other files, such as /Applications/EnergyPlus-9-6-0/PreProcess/GrndTempCalc/Basement
or /Applications/EnergyPlus-9-6-0/energyplus
run just fine.
- Any ideas what else I could try?
- Can anyone confirm if they get the same issue on macOS?
- Is this a potential bug and should I open an issue on Github?
