What is the value for cp Specific heat of the air in energy plus used?
We use in Europe cp= 1.0005 kJ/kgK but I guess might be different on other side :)
| 1 | initial version |
| 2 | retagged |
| 3 | retagged |
What is the value for cp Specific heat of the air air used in energy plus used?plus?
We normally use for air in Europe cp= 1.0005 kJ/kgK but I guess might be different on other side :)
What is the value for cp Specific heat of the air used in energy plus?
ps. I think here are errors in Units for cp
1. https://bigladdersoftware.com/epx/docs/9-6/engineering-reference/zone-internal-gains.html#heat-gain-from-lights
also, I found some value in some parts of documentation for cp https://bigladdersoftware.com/epx/docs/9-6/engineering-reference/green-roof-model-ecoroof.html#green-roof-nomenclature
cp
ps. I think here are errors there is an error in Units for cp (J/kg)
also, I found some cp= 1.0005 kJ/kgK value in some parts of documentation for cp cp, but not sure if this is unified approach?
| 9 | retagged |
ps. I think there is an error in Units for cp (J/kg)
also, I found cp= 1.0005 kJ/kgK value in some parts of documentation for cp, but not sure if this is unified approach?
| 10 | retagged |
