Does anyone know what are the resource requirements to deploy OpenStudio-server on AWS and run a PAT simulation in cloud server mode?
I'm having trouble with changing the AWS resource types other than what's recommended by NREL. I can successfully run a simulation using the settings stated in the GitHub page. The main failure occurs when trying assigning pods after changing the AWS instance type. For example, I tried changing t2.xlarge to t4g.xlarge instance which seems to be similar.
I would like to know what instance types we could use and what are the minimum requirements to consider for the following resources when allocating them.
- Minimum number of CPU's in a Node
- Minimum number of Nodes
- Minimum Storage for a Node (Default is 80GB)
- openstudio cluster: Minimums of nfs-server-provisioner.persistence.size and db.persistence.size (Default is 200GB)
