Hello,
I'm trying to understand whether is possible or not to change an already defined Air Flow Rate meanwhile the simulation is running in accordance with either a schedule or a predefined parameter.
Here is an example.
I am working on a building served by VRF units, all of which can work in accordance with 3 different Air Flow modes: Low, Medium, and High (approximated by using the Fan:SystemModel object). Here is my question:
Is there a way to change the air flow meanwhile the simulation is running? e.g. Making the current mode switching from high to medium in accordance to a schedule, a look-up table or a predefined condition, thus having complete control over the current fan-mode? Could the Python EMS be a solution? If so, any hints on how to implement this?
Many thanks for any help you can provide to me :-)
