I connected an Earth Tube to a greenhouse Zone, and want to get the exhaust air flow temperature, I assume the exhaust air flow volume is as same as the inlet/designed flow volume of the earth tube. 1. My first question is if the earth tube module gives an exhaust to the zone automatically at all? I don't find any information in I/O Reference to get any information about it. https://bigladdersoftware.com/epx/docs/9-3/input-output-reference/group-airflow.html#zoneearthtube-earth-tube 2. If I use Earth tube module, must the ZoneVentilation be actived and a openable window is required? I check the ZoneVentilation output the air flow volume is not the same as I gived to earth tube
