I am having a variety of issues trying to run a model file that I copied over from another computer. Initially, the weather file and OS results measure (the only measure added) both disappeared. I added the weather file back, but seem to still be having issues.
I get an immediate error if I run without the measure. I have tried every combination of re-adding and deleting the measure from OS and from the model file's measures folder. This removes the error, however OS keeps crashing. Either as soon as I start the simulation, or at the very end (after the output log prints "Complete"), or sometimes even when I save.
When it doesn't crash, I often get an error that one of the subsurfaces is missing a construction, even though I have repeatedly hard-assigned a construction to it.
Any help would be greatly appreciated.
Here are some of the errors I'm getting from run.log (if it makes it to the end and crashes, there are no sever errors in eplusout.err):
[14:32:27.194816 ERROR] Found error in state 'initialization' with message ["Cannot find measure OpenStudioResults 1::/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:155:in `block in validate_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:141:in `each'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:141:in `each_with_index'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:141:in `validate_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/jobs/run_initialization.rb:122:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/run.rb:287:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/run.rb:229:in `run'\n:/openstudio_cli.rb:1013:in `execute'\n:/openstudio_cli.rb:803:in `execute'\n:/openstudio_cli.rb:1797:in `<main>'\neval:185:in `eval'\neval:185:in `require_embedded_absolute'\neval:170:in `block in require_embedded'\neval:164:in `each'\neval:164:in `require_embedded'\neval:123:in `require'\neval:3:in `<main>'"]}
[13:45:28.182268 WARN] EnergyPlus reported area is 6372 (m^2). OpenStudio reported area is 9723 (m^2).
[13:45:31.163006 WARN] Interior Lighting Summary section failed and was skipped because: Optional not initialized. Detail on error follows: C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:3355:in `get'
C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:3355:in `block in interior_lighting_section'
C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:3354:in `each'
C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/resources/os_lib_reporting.rb:3354:in `interior_lighting_section'
(eval):1:in `block in run'
C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/measure.rb:291:in `eval'
C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/measure.rb:291:in `block in run'
C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/measure.rb:287:in `each'
C:/Users/nsimhai/AppData/Local/Temp/osmodel-1636490672-1/resources/measures/OpenStudioResults 1/measure.rb:287:in `run'
:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:521:in `apply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:67:in `each_index'
:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/jobs/run_reporting_measures.rb:117:in `perform'
eval:185:in `eval'
eval:164:in `each'
eval:3:in `<main>'
[13:10:37.622450 WARN] EnergyPlus returned a non-zero exit code. Check the stdout-energyplus log.
[13:10:37.624762 ERROR] :/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/energyplus.rb:187:in `call_energyplus'
:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in `perform'
eval:185:in `eval'
eval:164:in `each'
eval:3:in `<main>'
[13:10:37.625874 ERROR] Found error in state 'simulation' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/energyplus.rb failed with EnergyPlus Terminated with a Fatal Error. Check eplusout.err log., :/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/energyplus.rb:187:in `call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/run.rb:287:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/run.rb:229:in `run'\n:/openstudio_cli.rb:1013:in `execute'\n:/openstudio_cli.rb:803:in `execute'\n:/openstudio_cli.rb:1797:in `<main>'\neval:185:in `eval'\neval:185:in `require_embedded_absolute'\neval:170:in `block in require_embedded'\neval:164:in `each'\neval:164:in `require_embedded'\neval:123:in `require'\neval:3:in `<main>'::/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/energyplus.rb:205:in `rescue in call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/util/energyplus.rb:202:in `call_energyplus'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/jobs/run_energyplus.rb:63:in `perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/run.rb:287:in `step'\n:/ruby/2.7.0/gems/openstudio-workflow-2.2.1/lib/openstudio/workflow/run.rb:229:in `run'\n:/openstudio_cli.rb:1013:in `execute'\n:/openstudio_cli.rb:803:in `execute'\n:/openstudio_cli.rb:1797:in `<main>'\neval:185:in `eval'\neval:185:in `require_embedded_absolute'\neval:170:in `block in require_embedded'\neval:164:in `each'\neval:164:in `require_embedded'\neval:123:in `require'\neval:3:in `<main>'"]}
