Hey everyone! I'm getting this error when I try to run a calibration simulation after I upgraded from 3.2.1 to 3.3.0. any ideias???
/opt/openstudio/server/app/lib/analysis_library/rgenoud.rb failed with voidEval failed: , /usr/local/lib/ruby/gems/2.7.0/gems/rserve-client-0.3.5/lib/rserve/connection.rb:178:in `void_eval'
complete error log:
/opt/openstudio/server/app/lib/analysis_library/rgenoud.rb failed with voidEval failed: , /usr/local/lib/ruby/gems/2.7.0/gems/rserve-client-0.3.5/lib/rserve/connection.rb:178:in `void_eval' /usr/local/lib/ruby/gems/2.7.0/gems/rserve-simpler-0.0.6/lib/rserve/simpler.rb:74:in `command' /opt/openstudio/server/app/lib/analysis_library/r/cluster.rb:83:in `start' /opt/openstudio/server/app/lib/analysis_library/rgenoud.rb:224:in `perform' /opt/openstudio/server/app/jobs/resque_jobs/run_analysis.rb:43:in `perform' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/job.rb:168:in `perform' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:308:in `perform' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:897:in `block in perform_with_fork' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:895:in `fork' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:895:in `perform_with_fork' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:264:in `work_one_job' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:238:in `block in work' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:235:in `loop' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/worker.rb:235:in `work' /usr/local/lib/ruby/gems/2.7.0/gems/resque-2.0.0/lib/resque/tasks.rb:20:in `block (2 levels) in <top (required)>' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `block in execute' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `each' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:281:in `execute' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:219:in `block in invoke_with_call_chain' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `synchronize' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:199:in `invoke_with_call_chain' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/task.rb:188:in `invoke' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:160:in `invoke_task' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block (2 levels) in top_level' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `each' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:116:in `block in top_level' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:125:in `run_with_threads' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:110:in `top_level' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:83:in `block in run' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:186:in `standard_exception_handling' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/lib/rake/application.rb:80:in `run' /usr/local/lib/ruby/gems/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>' /usr/local/bin/rake:23:in `load' /usr/local/bin/rake:23:in `<top (required)>' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `load' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:63:in `kernel_load' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/cli/exec.rb:28:in `run' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/cli.rb:476:in `exec' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor.rb:399:in `dispatch' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/cli.rb:30:in `dispatch' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/vendor/thor/lib/thor/base.rb:476:in `start' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/cli.rb:24:in `start' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/exe/bundle:46:in `block in <top (required)>' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/lib/bundler/friendly_errors.rb:123:in `with_friendly_errors' /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.1.4/exe/bundle:34:in `<top (required)>' /usr/local/bin/bundle:23:in `load' /usr/local/bin/bundle:23:in `<main>'
