I've seen pump differential pressure reset used as a control strategy to reduce pump energy consumption. I imagine that in many simulation packages (including Energyplus), this would be modelled using a pump curve based on empirical data to modify energy consumption at varying flows. Does anyone know of a good resource to source either the data or curve for this?
