Hi all,
I am wondering if it is possible to access autosized values from PythonPlugin, for example is it possible to access maximum water flow rate of coils? If so, how pls?
I read, that sizing values should be available as internal variables but I cannot find list of internal variables which can be queried from python plugin... I looked into *.edd file, there are some sizing values, but I have not found anything close to maximum water flow rate there...
Thank you!
Coil:Heating:Water,
Basement VAV Box Reheat Coil, !- Name
ALWAYS_ON, !- Availability Schedule Name
AUTOSIZE, !- U-Factor Times Area Value {W/K}
AUTOSIZE, !- Maximum Water Flow Rate {m3/s}
