I am using PAT 3.1.0 to compare different alternatives, I run the workflow manually and I want to use the SI units.
In the reporting measures, I added the openstudio results and I changed the unit system to SI. But, in the sammary table report, units are in IP.
- Where can i change the units system for the summary table?
- Is it possible to personnalize the variables that will be compared: for exemple, by default, the summary table shows district cooling and heating savings but i would like to have the cooling and heating loads savings in general when modelling heating and cooling coils.
