Hi,
I am trying to generated the openstudio prototype buildings from the NREL GitHub Library. When I am trying to run the bundles in Git Bash, here is the message that I get:
$ bundle exec rake build
C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/resolver.rb:278:in block in verify_gemfile_dependencies_are_found!': Could not find gem 'minitest-reporters' in locally installed gems. (Bundler::GemNotFound)
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/resolver.rb:253:ineach'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/resolver.rb:253:in verify_gemfile_dependencies_are_found!'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/resolver.rb:50:instart'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/resolver.rb:23:in resolve'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/definition.rb:262:inresolve'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/definition.rb:483:in materialize'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/definition.rb:234:inspecs_for'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/runtime.rb:18:in setup'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler.rb:149:insetup'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/setup.rb:20:in block in <top (required)>'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/ui/shell.rb:136:inwith_level'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/ui/shell.rb:88:in silence'
from C:/Ruby30-x64/lib/ruby/gems/3.0.0/gems/bundler-2.2.29/lib/bundler/setup.rb:20:in<top (required)>'="" from="" <internal:c:="" ruby30-x64="" lib="" ruby="" 3.0.0="" rubygems="" core_ext="" kernel_require.rb="">:85:in require'
from <internal:C:/Ruby30-x64/lib/ruby/3.0.0/rubygems/core_ext/kernel_require.rb>:85:inrequire'
I would appreciate it if anyone could provide some ideas on how to resolve this and generate the prototype buildings.
Best, Mohammad
