I am modeling a building with 2 underground floors and 7 above floors in the development wizard when I create the 6th floor there is some errors that appear when i start the compliance analysis and if I copy the 5th floor this errors are solved but I can't do that because I have different shapes can someone help me. 2021-Oct-15 14:27:03- Ruleset Error: Default the Type of Terminal: CRule::Eval() post result 'DEFAULT' value to BDL failed 2021-Oct-15 14:27:03 - Ruleset Error: Default the Type of Terminal: CRule::Eval() post result 'DEFAULT' value to BDL failed 2021-Oct-15 14:27:03 - Ruleset Error: Default the Type of Terminal: CRule::Eval() post result 'DEFAULT' value to BDL failed 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to DAY-SCHEDULE component 'OfficeHeatA' imported from library: Error setting symbolic value to BDL (DBID=30001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to DAY-SCHEDULE component 'OfficeHeatNA' imported from library: Error setting symbolic value to BDL (DBID=30001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to DAY-SCHEDULE component 'OfficeHeatSatA' imported from library: Error setting symbolic value to BDL (DBID=30001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to WEEK-SCHEDULE component 'OfficeHeatAWinWK' imported from library: Error setting symbolic value to BDL (DBID=20001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to DAY-SCHEDULE component 'OfficeCoolNA' imported from library: Error setting symbolic value to BDL (DBID=30001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to WEEK-SCHEDULE component 'OfficeCoolNAWinWK' imported from library: Error setting symbolic value to BDL (DBID=20001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to DAY-SCHEDULE component 'OfficeCoolA' imported from library: Error setting symbolic value to BDL (DBID=30001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to DAY-SCHEDULE component 'OfficeCoolSatA' imported from library: Error setting symbolic value to BDL (DBID=30001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to WEEK-SCHEDULE component 'OfficeCoolSumAWK' imported from library: Error setting symbolic value to BDL (DBID=20001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to WEEK-SCHEDULE component 'OfficeHeatNASumWK' imported from library: Error setting symbolic value to BDL (DBID=20001000) evaluating rule: Set Fan Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to DAY-SCHEDULE component 'OfficeCoolJuneA' imported from library: Error setting symbolic value to BDL (DBID=30001000) evaluating rule: Set Cooling Schedule 2021-Oct-15 14:27:03 - Ruleset Error: Error encountered setting data to WEEK-SCHEDULE component 'OfficeCoolJuneAWK' imported from library: Error setting symbolic value to BDL (DBID=20001000) evaluating rule: Set Cooling Schedule
