Program Version,EnergyPlus, Version 8.7.0-78a111df4a, YMD=2021.10.14 00:29,IDD_Version 8.7.0 * Warning * Output:PreprocessorMessage="ExpandObjects" has the following Warning conditions: * ~~~ * In HVACTemplate:System:VRF "VRF-system" for the field Zone Name for Master * ~~~ * Thermostat Location could not find a matching HVACTemplate:Zone:VRF named: *** IDF Context for following error/warning message: *** Note -- lines truncated at 300 characters, if necessary... *** 5183 Boiler:HotWater, *** indicated Name=boiler *** Only last 2 lines before error line shown..... *** 5184 boiler, !- Name *** 5185 , !- Fuel Type * Severe * IP: IDF line~5185 Error detected in Object=BOILER:HOTWATER, name=BOILER * ~~~ * Field [Fuel Type] is required but was blank * Severe * IP: Blank "required" fields found in input * Severe * IP: Out of "range" values and/or blank required fields found in input * Fatal * IP: Errors occurred on processing IDF file. Preceding condition(s) cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=3 ..... Last severe error=IP: Out of "range" values and/or blank required fields found in input *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 0 Warning; 0 Severe Errors. *** EnergyPlus Terminated--Fatal Error Detected. 1 Warning; 3 Severe Errors; Elapsed Time=00hr 00min 0.39sec
i saw a few posted talk about construstion set. related?
