I'm trying to add the OS objects OS:Coil:Heating:WaterToAirHeatPump:EquationFit and OS:Coil:Cooling:WaterToAirHeatPump:EquationFit to an air loop in my model. While I believe I the object has been added correctly, when I run the model with these coils in them, I get the following error:
* ~~~ * ..Invalid Air Loop Component Type = "COIL:HEATING:WATERTOAIRHEATPUMP:EQUATIONFIT".
Has anyone encountered this problem/ Is there a way to know which object I should be using instead? Thank you for any information you'd be willing to provide me.
