Is there a way to remove unwanted Output:Meter and Output:Table:Monthly objects or suppress them from flagging errors? I was hoping to delete the objects inapplicable to my model's load cases, but it seems these are not objects that can be accessed through an EnergyPlus measure. I understood they are added by OpenStudio upon translation to the analysis IDF.
If they are indeed inaccessible through an EnergyPlus, are there any ways to stop these from flagging a warning in the eplusout.err file without manually editing the analysis IDF?
Many thanks.
