Hi All, I am trying to model a variable flow unit in eQuest 3.65 b.7173. In this system, I would like the airflow to each zone to be controlled by a schedule that determines when the diffusers are open (and available) vs when the diffusers are fully closed (and unavailable). I have attempted to add a "minimum flow schedule" under the "air flow" tab for each zone, using "0" when I want the airflow to be zero, and "1" otherwise without success. Could someone run me through how to set this up or direct me to an appropriate example to reference? Thanks!
