Hi All, I hope you are doing fine.
I have a system with the embedded pipe in a masonry wall for space cooling. The aim is to get the water, wall's surface, and room temperature changes. Also, obtaining the cooling capacity of this system is another crucial parameter.
I am wondering whether the simulation of this system is doable with EnergyPlus or not.
Thank you. Best regards, Mohammad
