My model runs fine. Yay! However, I want to scrutinize what's happening with the ground slab heat transfer: is the heat transfer reasonable? how is the heat transfer being calculated and what are the ground temperatures in the model? There's a good number of posts that mention ground temperatures, but I have not found any that describe how to either look at model results since my model runs, or to look at the osm/idf/other file to inspect how ground temperature is being addressed. Could someone help me with that?
