I am using the Energyplus-API for simulation. So I am using the same python-script at home and at work. Both OS are Ubuntu 20.04 and only differences is the python version (work: 3.8; home:3.9). So at work everything is fine. My simulation is running and there are no complaints. But if i run the same script at home, with the same packages installed, I get an epw-file error. Here is the relevant output from the error-file. I am really clueless, because it is the same script with the same epw-file. And to increase the confusion, if I use the same epw-file on a small API simulation at home, there is no error. Just in the simulation script, which includes classes, there is an error. I thought maybe it is because of different package version or PyCharm, but I deleted and reinstalled everything and still there is the same problem. Maybe somebody came across a similar case.
Thank you very much in advance and have a nice day :)
************* Beginning Simulation
** Severe ** Invalid Weather Line at date=1986/ 1/ 2 Hour#= 1 Min#=60
** ~~~ ** Full Data Line=1986,1,2,1,60,A7A7E8E8*0?9? 9A7A7A7A7A7A7*0E8*0*0,
-6.3,-7.8,88,95200,0,1415,227,0.0,0.0,0,0,0,0,0,170,1.0,7,2,12.0,7500,9,999999999,0,0.0560,1,88,0.000,0.0,0.0
** ~~~ ** Remainder of
line=-6.3,-7.8,88,95200,0,1415,227,0.0,0.0,0,0,0,0,0,170,1.0,7,2,12.0,7500,9,999999999,0,0.0560,1,88,0.000,0.0,0.0
** Fatal ** Error in Reading Weather Data
...Summary of Errors that led to program termination:
