Program Version,EnergyPlus, Version 9.5.0-de239b2e5f, YMD=2021.09.14 13:45, *** Beginning Zone Sizing Calculations * Severe * ProcessScheduleInput: Schedule:Year="オフィス照明 - 午前 6 時~午後 11 時" has missing days in its schedule pointers * Severe * ProcessScheduleInput: Schedule:Year="一般オフィス 使用 - 午前 8 時~午後 5 時" has missing days in its schedule pointers * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS_ON", Blank Schedule Type Limits Name input -- will not be validated. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS ON DISCRETE", Blank Schedule Type Limits Name input -- will not be validated. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated. * Warning * ProcessScheduleInput: Schedule:Constant="ALWAYS ON CONTINUOUS", Blank Schedule Type Limits Name input -- will not be validated. * Fatal * ProcessScheduleInput: Preceding Errors cause termination. ...Summary of Errors that led to program termination: ..... Reference severe error count=2 ..... Last severe error=ProcessScheduleInput: Schedule:Year="一般オフィス 使用 - 午前 8 時~午後 5 時" has missing days in its schedule pointers *** Warning: Node connection errors not checked - most system input has not been read (see previous warning). *** Fatal error -- final processing. Program exited before simulations began. See previous error messages. *** EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors. *** EnergyPlus Sizing Error Summary. During Sizing: 4 Warning; 2 Severe Errors.
*** EnergyPlus Terminated--Fatal Error Detected. 4 Warning; 2 Severe Errors; Elapsed Time=00hr 00min 0.27sec
Above is my eplusout.err file, the geometry model was exported from Revit then gotten into OS via gbXML. The main problem is that though the error report tells me where is abnormal, I cannot find the schedule under Schedule tab in my model. Besides, the name of the schedule is the same as the one I find in my Revit model, which means that the schedule comes from Revit, even if I can neither find nor edit it, and it is fragmentary.
