How do I show a tempering valve in a plant loop? I can't add it to the connector list, so I'm at a loss. Thanks!
| 1 | initial version |
| 2 | retagged |
How do I show a tempering valve in a plant loop? loop using EnergyPlus? I can't add it to the connector list, so I'm at a loss. Thanks!
| 4 | retagged |
How do I show a tempering valve in a plant loop using EnergyPlus? I can't add it to the connector list, so I'm at a loss. Thanks!
Update: A tempering valve (a.k.a. thermostatic mixing valve) must be entered as its own branch object (rather than a connector.
| 7 | retagged |
