We have recently upgraded to OpenStudio 3.2.0 and in the process have been modelling spaces using SketchUp 2021 and the OpenStudioApp 1.2.0. We have found that modelling 128 spaces breaks the space, surface and subsurface tabs in the OpenStudioApp 1.2.0 in which no model information shows on the screen. This tab works perfectly fine with 127 spaces. We can also revert from 128 to 127 spaces and the information shows up again.
Creating spaces been tested on three different machines and I have tried the following methods, of which none work successfully past 127 spaces: 1) Creating spaces in SketchUp 2021 using the OpenStudio Plugin for 3.2.0 2) Creating the spaces manually in the OpenStudio application 1.2.0 3) Creating the spaces using Ladybug Tools in Rhino3d v7
The only success we have had is in upgrading a previous model from OpenStudio 2.7.1, where the information shows for a model with 320 spaces.
Does anyone have any potential fixes or other workflows around this possible limitation?
