After applying "Ideal Air Load" measure for whole system, the error output file shows the following warning error. Would you please help me to fix the errors. Your help is highly appreciated.
The first bunch of warning error: * Warning * Output:Meter:MeterFileOnly: invalid Key Name="SUM ZONE IDEAL LOADS HEAT RECOVERY LATENT COOLING ENERGY 2" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="SUM ZONE IDEAL LOADS HEAT RECOVERY LATENT HEATING ENERGY 2" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="SUM ZONE IDEAL LOADS HEAT RECOVERY SENSIBLE COOLING ENERGY 2" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="SUM ZONE IDEAL LOADS HEAT RECOVERY SENSIBLE HEATING ENERGY 2" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="SUM ZONE IDEAL LOADS HEAT RECOVERY TOTAL COOLING ENERGY 2" - not found. * Warning * Output:Meter:MeterFileOnly: invalid Key Name="SUM ZONE IDEAL LOADS HEAT RECOVERY TOTAL HEATING ENERGY 2" - not found.
The second bunch of warnings is as follows: * Warning * Referenced variable or meter used in the wrong context "GERMINATION ROOM TZ-1 IDEAL LOADS AIR SYSTEM" of type "ZONEHVAC:IDEALLOADSAIRSYSTEM" * Warning * Referenced variable or meter used in the wrong context "GROWING ROOM TZ-3 IDEAL LOADS AIR SYSTEM" of type "ZONEHVAC:IDEALLOADSAIRSYSTEM" * Warning * Referenced variable or meter used in the wrong context "OFFICE ROOM TZ-2 IDEAL LOADS AIR SYSTEM" of type "ZONEHVAC:IDEALLOADSAIRSYSTEM"
