Visual Result for Added PV Panels
For PV Analysis, firstly I created shading in gbXML file and then import it into OS to add PV shading. The measure I used is an EnergyPlus one, which is Add Simple PV to Specified Shading Surfaces. This measure can only be used through the Measure tab but not Apply Measure Now. The problem is that how can I check the visual information in OS then? It won't appear in geometry or shading in Facility.
