How to model a Utility Tariff based on Rate Qualification Demand
Hi,
I was wondering if anyone could assist me with the following tariff question, where demand charge would not be qualified based on the maximum annual demand. In other words, the threshold value of UtilityCost:Tariff should follow the third largest (not the maximum annual) as described below (for instance for 200 kW):
The Customer whose monthly Maximum Demand is expected to reach 200 kW or has reached 200 kW for any three months during the preceding 12 months is ineligible for service under this Schedule.
I truly appreciate your support in advance.
Hi,
How to model a Utility Tariff based on Rate Qualification DemandDemand Rate
Hi,
I was wondering if anyone could assist me with the following tariff question, where demand charge would not be qualified based on the maximum annual demand. In other words, in my mode, the threshold value of UtilityCost:Tariff should follow the third largest (not the maximum annual) as described below (for instance for 200 kW):
How to model a Utility Tariff based on Qualification Demand Rate
Hi,
I was wondering if anyone could assist me with the following tariff question, where demand charge would not be qualified based on the maximum annual demand. In other words, in my mode, model, the threshold value of UtilityCost:Tariff should follow the third largest (not the maximum annual) as described below (for instance for 200 kW):
Hi,
I was wondering if anyone could assist me with the following tariff question, where demand charge would not be qualified based on the maximum annual demand. In other words, in my model, the threshold value of UtilityCost:Tariff should follow the third largest monthly demand (not the maximum annual) as described below (for instance for 200 kW):
Hi,
I was wondering if anyone could assist me with the following tariff question, where demand charge would not be qualified based on the maximum annual demand. In other words, in my model, the threshold value of UtilityCost:Tariff should follow the third largest monthly demand (not the maximum annual) )- as described below (for instance for 200 kW):
Hi,
I was wondering if anyone could assist me with the following tariff question, where demand charge would not be qualified based on the maximum annual demand. In other words, in my model, the threshold value of UtilityCost:Tariff should follow the third largest monthly demand (not the maximum annual)- as described below (for instance for 200 kW):
The "The Customer whose monthly Maximum Demand is expected to reach 200 kW or has reached 200 kW for any three months during the preceding 12 months is ineligible for service under this Schedule.Schedule."
Hi,
"The Customer whose monthly Maximum Demand is expected to reach 200 kW or has reached 200 kW for any three months during the preceding 12 months is ineligible for service under this Schedule."
How to model a Utility Tariff based on Qualification Qualifying Demand Rate
Hi,
How to model a Utility Tariff based on Qualifying Demand RateRate?
Hi,
I was wondering if anyone could assist me with the following tariff question, where demand charge would not be qualified based on the maximum annual demand. In other words, in my model, the threshold value of UtilityCost:TariffUtilityCost:Qualify should follow the third largest monthly demand (not the maximum annual)- as described below (for instance for 200 kW):
How to model a Utility Tariff based on Qualifying Demand Rate?
Hi,
In other words, I modeling a utility tariff, where I have more than kW threshold and consequently, using UtilityCost:Qualify- in my model, order to select a proper range of tariffs for each category. However, the threshold value of UtilityCost:Qualify should follow provided by the service company follows the third largest monthly demand demand"" (not the maximum **maximum annual)- as described below (for instance for 200 kW):
Hi,
In other words, I modeling a utility tariff, where I have more than kW threshold and consequently, using UtilityCost:Qualify- in order to select a proper range of tariffs for each category. However, the threshold value provided by the service company follows the third largest monthly demand"" demand (not the **maximum maximum annual)- as described below (for instance for 200 kW):
Hi,
In other words, I modeling a utility tariff, where I have more than one kW threshold and consequently, using UtilityCost:Qualify- in order to select a proper range of tariffs for each category. However, the threshold value provided by the service company follows the third largest monthly demand (not the maximum annual)- as described below (for instance for 200 kW):
Hi,
"The Customer customer whose monthly Maximum Demand is expected to reach 200 kW or has reached 200 kW for any three months during the preceding 12 months is ineligible for service under this Schedule."schedule."
