Hello! I am using OpenStudio and would like to know how to remove a measure completely. I applied the "Air Wall Zone Mixing" measure between two zones that had air walls defined. I then removed the air walls but still see the zone mixing ongoing - I could see this in Data Viewer. I even deleted the measure from the local library but the zone mixing continues. Is there any way to remove this measure completely? Thank you so much!
