I am running Create Bar From Space Type Ratios measure and I am getting an error
* Severe * <root>[BuildingSurface:Detailed][Surface 1] - Missing required property 'construction_name'. * Severe * <root>[FenestrationSurface:Detailed][Sub Surface 1] - Missing required property 'construction_name'. * Fatal * Errors occurred on processing input file. Preceding condition(s) cause termination.
The measure says we need to run an empty model and there is no argument to define the Construction in the measure, what can I do?
