asked 3 years ago
antonszilasi's avatar
OpenStudio-standards college space types
I am attempting to use the college ASHRAE space types in our workflow by obtaining the space type properties from OpenStudio-standards with the following code:
osstandards.standards_data['space_types']
Unfortunately Ive found there is no lighting per area, equipment per area and in some cases no occupancy in college space types where there should be. This is across ashrae templates 2007,2010,2013,2016.
For good measure I have written some code which checks this and I have attached a spreadsheet which the code produces find it on google sheets here:https://docs.google.com/spreadsheets/d/1zzxllx6nny-t3PyxcdK5k8e5MApbEwlr2_y-_dCLFi4/edit?usp=sharing
Is there a reason for this? If not is this something which needs to be fixed?
I am using OpenStudio-standards 0.2.14
For good measure I have written some code which checks this and I have attached a spreadsheet which the code produces find it on google sheets here:https://docs.google.com/spreadsheets/d/1zzxllx6nny-t3PyxcdK5k8e5MApbEwlr2_y-_dCLFi4/edit?usp=sharinghere: link text
