Hello,
I want to use Unmet Load Hours Troubleshooting Measure to find a way to reduce unmet hours. After the simulation runs smoothly i get this error:
Result: Fail
Error: undefined method getDesignLoopExitTemperature' for #<OpenStudio::Model::SizingPlant:0x0000020d6fff4f50>
C:/Users/ENGINE~1/AppData/Local/Temp/osmodel-1625569532-0/resources/measures/Unmet Load Hours Troubleshooting/measure.rb:291:inblock in plant_loop_temp_vs_setpoints'
C:/Users/ENGINE~1/AppData/Local/Temp/osmodel-1625569532-0/resources/measures/Unmet Load Hours Troubleshooting/measure.rb:274:in each'
C:/Users/ENGINE~1/AppData/Local/Temp/osmodel-1625569532-0/resources/measures/Unmet Load Hours Troubleshooting/measure.rb:274:inplant_loop_temp_vs_setpoints'
C:/Users/ENGINE~1/AppData/Local/Temp/osmodel-1625569532-0/resources/measures/Unmet Load Hours Troubleshooting/measure.rb:558:in run'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:519:inapply_measure'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:114:in block in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:ineach_index'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/util/measure.rb:67:in apply_measures'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/jobs/run_reporting_measures.rb:105:inperform'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:292:in step'
:/ruby/2.5.0/gems/openstudio-workflow-2.1.0/lib/openstudio/workflow/run.rb:234:inrun'
:/openstudio_cli.rb:971:in execute'
:/openstudio_cli.rb:761:inexecute'
:/openstudio_cli.rb:1755:in <main>'
eval:175:ineval'
eval:175:in require_embedded_absolute'
eval:160:inblock in require_embedded'
eval:154:in each'
eval:154:inrequire_embedded'
eval:113:in require'
eval:3:in<main>'
How can i resolve this? I' m using the sketch up plugin for Sketch up 2019.
Thank you in advance
